Thread: $1200 limit, suggestions on media center pc |
Bronze Member Username: Durski
Post Number: 19 Registered: Nov-06
| Posted on Thursday, May 17, 2007 - 10:44 pm: |
I have a $1200 budget, I need to build a pc with audio engineering / editing capabilities. I need the whole thing with monitor, and 7.1 surround speakers, i can find those just fine but they need to be taken into consideration with respect to the budget. Any ideas? |
Gold Member Username: The_image_dynamic
San Diego
Post Number: 1440 Registered: Dec-06
| Posted on Monday, May 21, 2007 - 06:28 am: |
Go to www.newegg.com and piece together a system. If you are unsure of brands and hardware types, use the reviews as guidelines. If you need further help, let me know and I can put together a suitable system for you. Keep in mind that "audio engineering/editing capabilities" is software driven, and almost any decent new system will have the ability to run those programs. |
Post Number: 20 Registered: Nov-06
| Posted on Tuesday, May 22, 2007 - 04:18 pm: |
I have known and loved newegg for a long time and I have built many pc's, but I'm not sure what an audio engineering pc would need that would be different than... say a gaming pc or regular work station. I assume some sort of 8 channel sound card... I draw a blank after that. Was really wondering if anyone has an Audio editing pc that they're happy with, and if they could share a little about it, and some of the apps they use. Thanks for the help so far. |
Silver Member Username: Stefanom
Vienna,
VA
United States
Post Number: 601 Registered: Apr-06
| Posted on Wednesday, May 23, 2007 - 08:17 am: |
Processing power, RAM, and hard drive space will likely be a plus in addition to the sound card. You should be able to skimp on graphics power without any major ill effects. |
