Thread: Help with Samsung wirless keyboard and mouse? |
Bronze Member Username: Shane24
Post Number: 100 Registered: Mar-07
| Posted on Wednesday, April 18, 2007 - 04:49 am: |
I' have been using samsung's wireless keyboard and mouse for 2 yrs now, model noSDR5000K, initially it served well, but 6months down the line i faced some difficulty with it.. I noticed there was a lot of drainage on the batteries and, I use energizer lithium batteries, which are supposed to give extra life, but of no use.... then faced trouble with receiver, it wasn't responding well... hence, I have to change the batteries every 2-3weeks... I did get some info regarding this predicament, and some said that this is a common problem faced by these wireless keyboard's and mouse, some said try logitech, they are supposed to be the best.. and I don't even use the p.c very often for this can of drainage on batteries and mouse not responding well... help needed... thnks |
Silver Member Username: Stefanom
Vienna,
VA
United States
Post Number: 499 Registered: Apr-06
| Posted on Wednesday, April 18, 2007 - 09:07 am: |
Try a good set of rechargeable batteries. It is a moderate one time investment (~20 bucks or so), but other than that, you should be good to go for a long time. |
Silver Member Username: Shane24
Post Number: 105 Registered: Mar-07
| Posted on Thursday, April 19, 2007 - 11:12 am: |
stephen, I tried that to, but it was the same story... i guess i should change it to logitech i read a lot of good reviews abt them.... |
Silver Member Username: Mrskullz1
Brooklyn, New York
Post Number: 481 Registered: Feb-07
| Posted on Friday, May 25, 2007 - 05:36 pm: |
logitech is great company |
Bronze Member Username: Kensongoo
Post Number: 20 Registered: Apr-06
| Posted on Tuesday, June 05, 2007 - 06:02 pm: |
Yes, i strongly recommends logitech. However the price is a little bit high |
