Home > Message Board > Computers > Sound Cards > Do I need a sound card?
Author Thread: Do I need a sound card?
Username: Jmsoave
South Lake Tahoe, CA
Post Number: 50
Despite all my home stereo hi-fi knowledge and experience, I've never bridged the gap between my PC and my home stereo. I've got loads of music on my PC in SonicStage. I know that I can simply hook up my PC to the stereo using a minijack-to-RCA cable, but is this going to get me the best sound? Or will a sound card improve the sound quality? I've read some postings that seem to imply that a sound card would be redundant in this case. I'm confused by all the sound card info out there, so any help or advice would be greatly appreciated...
The signal would be going into a 2-channel integrated amplifier.
Username: Stefanom
Vienna, VA
United States
Post Number: 493
Depends on what you're willing to spend for best sound. Getting an external sound card, and then using a digital connection from that to a high end DAC should give you the best possible sound from your PC. However, if you're just running 128kbps mp3s, your standard output should be fine. If nothing else, you'll be out all of six bucks for that experiment.
Username: Jmsoave
Post Number: 52
This will be mostly mp3's and atrac3's, so you seem to think it's not worth an upgrade? I forgot to mention that this is a notebook computer, and that mobility is key...does that change the equation?
I've got my eye on this:
http://www.echoaudio.com/Products/CardBus/IndigoIO/index.php
Username: Stefanom
Vienna, VA
United States
Post Number: 497
Depending on what you have now, it might make some difference. However, if the source is going to be low grade mp3s, there are limits as to what you can expect. In either case, I would try it with the standard integrated sound card in your machine now, and see how it sounds before upgrading.
Username: Msvara
Post Number: 36
I would like to add a comment about sound cards. I had the Audigy 2 ZS and upgraded to the X-Fi and WOW! there is an option in the mixer called Crystalize and when you set that to maximum it really enhances the music. Also it bundles with a great Audio Creation Mixer that allows you to add effects to inputs during recording. One more benefit is they added a Game mode that allocates the available buffer RAM to work in such a way that games benefit and takes the load off the main CPU.
Username: Shane24
Post Number: 142
Mark is right, big improvement from audigy to x-fi especially the onboard 64mb ram, well I would assume u listen to mp3,wma,acc and related file formats, if ur looking for cd-quality then I would suggest to upgrade to the x-fi coz 192kbs mp3 is considered cd-quality...
Username: Stefanom
Vienna, VA
United States
Post Number: 528
A: For top quality sound, use lossless formats, not mp3.
B: Something like this....
http://www.tnt-audio.com/sorgenti/trendsaudio_ud10_e.html
Will likely outperform anything Creative Labs puts out.
Username: Msvara
Post Number: 37
Good to know Stephen. Thanks for the post. My wife is a singer and we're always looking for inexpensive audio improvments.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Sound Cards > Do I need a sound card? [ « Previous ] [ Next » ]
