Home > Message Board > Computers > Cases & Cooling > Power supply of over 400watts...
Author Thread: Power supply of over 400watts...
Username: Shane24
Post Number: 59
Yeah, i would like to know if there are atx cases of over 400watts of power supply.. and how many fans can one fix in a standardpc, which is pentium 4(3.2ghz).. (intel chipset)
I already have a fan fixed which is used for the processor.. is it possible to add another, coz all of my power cables are used... or should i change the case? suggestions much appreciated..
Username: Stefanom
Vienna, VA
United States
Post Number: 458
There are lots of power supplies over 400 watts if that is what you mean. As for how many fans you can add, it depends on the case. I personally think more than two case fans are a waste in most areas.
If you are extremely concerned about cooling, look at something like Lian Li and couple it with a good power supply from Enermax or Antec.
Username: Illuminator
Post Number: 4918
Yeah, it depends on the case a ton.
Username: Mrskullz1
Brooklyn, New York
Post Number: 471
yea def the case
Username: Durski
Post Number: 98
its not the case, it's the psu
Username: Glasswolf
Wisteria, Lane
Post Number: 12154
look at a quality case from a company like Lian Li.
they generally take something like two 80mm fans in front, one 80mm exhaust fan, plus the power supply of your choosing.
My personal choice right now is the Enermax Modu82+ power supply.
That is if you go with a typical mid-tower case regarding the cooling.
I'm using a Lian Li PC12 (older model) Alu case now, as well as a CalPC small server cube which takes three 120mm fans. twi stacked front, one rear.
If you do want multiple cooling fans in the case, also consider a decent fanbus to control fan speeds.
the more fans you have, the more noise the PC will generate.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Cases & Cooling > Power supply of over 400watts... [ « Previous ] [ Next » ]
