Home > Message Board > Computers > Speakers > USB Inexpensive Speakers
Author Thread: USB Inexpensive Speakers
Username: Capecodder
On my home desktop, I principally use a USB-connected headset with microphone. (Creative SB Live audio card.) However,I would like to add a inexpensive USB speaker when I don't want to wear the headphones. I would like to unplug the headset and plug in the speakers without changing audio settings.
That is, the USB speakers should not need an audio cable connection. Many I have seen use the USB for power only.
Is it unrealistic to think I can swap the headset and speakers back and forth by merely unplugging one and plugging in the other??
Any suggestions on model/brand? Sound quality is NOT a major factor.
Username: Gamerdude
Ontario
Post Number: 441
Hey, check out logitech.com
they got some
Username: Wavfile
Boston, MA
Yes,
Logitech and usbgear has some as well- I would think Crutchfield likely does also.
Happy hunting
WavFile
Username: P4s
how cheap would your cheap be? price range please:
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Speakers > USB Inexpensive Speakers [ « Previous ] [ Next » ]
