Thread: Sounds Card to Amp cableing |
New member Username: Freestylepsycho
Post Number: 5 Registered: Dec-06
| Posted on Saturday, March 03, 2007 - 02:26 pm: |
Hi, I have a PCMCIA Sound Blaster® Audigy 2 ZS Notebook, sound card and this splits the output in to 3 separate signals, 1 for the 2 front speakers, 1 for the back left and right and one for the other speakers and the sub. What I am trying to do is get the first 2 which is the front 2 speakers and the back 2 and attach them to one RCA port on the amplifier. To do this I think I am going to have to get 2x 3.5mm to 2 RCA male adapter then attach them to 2x 2 RCA female to 1 RCA male adapter and then attach that to the amp. However I think this will merge the signals meaning there is only left and right, rather than left, right, back and front, Can anyone confirm that for me. Or will it keep the signals separate? Also can anyone thing of an easier way to do it? |
Relevant Product Info
Gold Member Username: Arande2
Extreme SQ FTW
Post Number: 1755 Registered: Dec-06
| Posted on Saturday, March 03, 2007 - 02:36 pm: |
What's your receiver? |
Post Number: 6 Registered: Dec-06
| Posted on Saturday, March 03, 2007 - 04:48 pm: |
I don't have one and I really don't see the point in getting one. |
Extreme SQ FTW
Post Number: 1770 Registered: Dec-06
| Posted on Saturday, March 03, 2007 - 04:51 pm: |
What's the amp then? The reason I asked for the receiver is because if it has multichannel inputs you can just run mini plug to RCA cables to the back 5.1 inputs. So what's the amp? |
Post Number: 7 Registered: Dec-06
| Posted on Saturday, March 03, 2007 - 05:10 pm: |
It's a NAD 3130, which will run the rear speakers and then use the preout to attach to a power amp and run the front 2. |
Extreme SQ FTW
Post Number: 1776 Registered: Dec-06
| Posted on Saturday, March 03, 2007 - 05:27 pm: |
It will merge the signals. Why can't you just separately run the signals to each amp? |
Post Number: 8 Registered: Dec-06
| Posted on Saturday, March 03, 2007 - 05:35 pm: |
I can, but it will mean that I can't run multiple sources into the NAD amp and then have both set of speakers playing the source. |
Extreme SQ FTW
Post Number: 1778 Registered: Dec-06
| Posted on Saturday, March 03, 2007 - 05:37 pm: |
I guess you'd have to set the sound card to 2 channel and run it as 2-channel if you wanted to do that...then it's bye to surround. |
Post Number: 9 Registered: Dec-06
| Posted on Sunday, March 04, 2007 - 06:18 pm: |
Ok, I have been thinking and it has just confused me. I can see how a receiver would solve the problem of the surround sound as each of the speaker would be going out of a designated channel, but surely you can only connect one source to each channel so how do you have multiple things using the same surround sound system, as if you attach them via a preamp then it will merge the signals and if you attach them to the receiver you will have to attach the 2 signals to one RCA port and therefore they will be merged in the process. And if you have a receiver with multiple channels you will only be able to run 1 channel at a time and therefore it will only play one of the sources (left and right or left back and right back) across 4 speakers. |
Bronze Member Username: Andreas
Post Number: 24 Registered: Sep-05
| Posted on Thursday, March 15, 2007 - 03:16 pm: |
some audigy cards had 4-pole not 3-pole jacks. If I remember correctly - green: front L, front R, ground black : rear L, rear R, side L ground orange: center, sub, side R, ground I mean if this is 7.1 card and it has 3 not for outs then 2 out of 3 have to convey 3 signals + ground not just 2. Unless you plan to have 7.1 you do not need special cables, but you need to know which out is for what channels... Check Creative knowledgebase, it must be covered there. Hope this helps, even if it is confusing at first ;) |
