Thread: Memorex burner |
New member Username: Sexyboy559
Post Number: 1 Registered: Feb-07
| Posted on Tuesday, February 27, 2007 - 04:07 pm: |
i just got this new memorex dvd burner because the one that came with my computer was burning them at 1x. i connected the new one and says its burning at 16x but its taking forever like if it is burning at 1x. can any one help? |
Gold Member Username: Samijubal
Post Number: 3332 Registered: Jul-04
| Posted on Sunday, March 04, 2007 - 12:48 pm: |
Go into device manager and make sure your hard drives are set to DMA and not PIO. |
Post Number: 2 Registered: Feb-07
| Posted on Sunday, March 04, 2007 - 01:38 pm: |
whats the difference? i called a local shop and they said my processor is to slow and that i would need to buy a whole new system because i cant change parts out since it is a sony? is this true. thanks |
Silver Member Username: Stefanom
Vienna,
VA
United States
Post Number: 422 Registered: Apr-06
| Posted on Monday, March 05, 2007 - 08:54 am: |
DMA allows faster transfer rates. What kind of machine/processor do you have? |
Post Number: 3 Registered: Feb-07
| Posted on Monday, March 05, 2007 - 09:48 am: |
its a sony pcv-rx752, and has a pentium 4 processor.i cant even find the device manager? |
Post Number: 3335 Registered: Jul-04
| Posted on Monday, March 05, 2007 - 11:14 am: |
Click control panel performance and maintence system hardware device manager double click IDE ATA/ATAPI controllers right click the HDs and click properties click advanced settings and make sure it's set to DMA. Complete garbage you need a new PC. |
Vienna,
VA
United States
Post Number: 424 Registered: Apr-06
| Posted on Monday, March 05, 2007 - 11:19 am: |
"Complete garbage you need a new PC." Yup. If the DMA thing doesn't pan out, I'd suggest digging into the burning software's settings to see if there is something restricting it. |
New member Username: Soundmairman
Post Number: 2 Registered: Mar-07
| Posted on Monday, March 05, 2007 - 11:44 am: |
What dvd+/-r disks do you use? I don't think that Pentium 4 is a old processor, as for the shop they would say anything to you just to buy something else from them. |
Post Number: 4 Registered: Feb-07
| Posted on Monday, March 05, 2007 - 03:07 pm: |
it is set to dma i just checked. for the disk it only lets me burn them onto dvd-r.so i just need a new comp? |
Post Number: 3339 Registered: Jul-04
| Posted on Monday, March 05, 2007 - 07:11 pm: |
You don't need a new PC. How many CD/DVD drives do you have? Make sure the burner is DMA too. Some burners will burn poor quality media slow. What brand and speed are the discs? |
Post Number: 5 Registered: Feb-07
| Posted on Monday, March 05, 2007 - 08:46 pm: |
i have 1 cd drive that just reads the cd and then the one on the top burns the cd/dvds. how do i no if these burner is dma it doesn't say? they are memerox the same as the burner. i already tried 3 differnt types. |
Post Number: 3340 Registered: Jul-04
| Posted on Monday, March 05, 2007 - 08:55 pm: |
Some PCs only allow DMA on the master drive. The burner should be set to master. You can check in device manager. Double click DVD/CD-ROM drives and right click the burner click properties if the location is 0, it's master, if the location is 1, it's slave. |
