Thread: Can anyone help with administrative issues? |
Gold Member Username: Matt12490
California
Post Number: 1651 Registered: May-05
| Posted on Friday, February 09, 2007 - 03:31 pm: |
I posted in off topic originally: http://forum.ecoustics.com/bbs/messages/289508/323472.html Thanks all! |
Gold Member Username: Nikk
Post Number: 1167 Registered: Sep-06
| Posted on Saturday, February 10, 2007 - 11:44 am: |
The only thing that can save you of not reinstalling everything is to log on as Administrator, the accout over you are actually login on the system has minor privileges, the only one who can assign privileges to any user is another user whith administrator privileges or the Admin itself. What I'm thinking at this point is that the account you were using had the attribute of password expiration, if that was the case, the password expired. What does the system tell you when you type the password you say doesn't work any more??.. Try to remember of a Admin account exists, did you installed the XP by yourself the first time??? If your problem is that you have valuable information that you might want to recover then take out the Hard Disk you have put the jumper in the "slave" position and plug it into another computer, then browse through wherever your files are and move everything into a CD or another disk, then take the drive out again, put the jumper back into "master" position, plug it into your PC and start installing XP again.... If the Admin account was deleted and the only configured account was the one that is not working then that's all man....there is nothing to do as far as I know.... Good Luck |
New member Username: Invincible
Post Number: 10 Registered: Jun-06
| Posted on Friday, February 16, 2007 - 08:32 pm: |
There is one simple solution. Restart your computer and keep tapping F8 key and start the computer in Safe Mode. Log on as Administrator in safe mode. Go to control panel,User Accounts and create another user or change your account type from limited to Administrator. Hope this helps |
