Thread: Sound Card for Audiophiles. Any recommendations |
New member Username: Rowanc
Post Number: 1 Registered: Jan-07
| Posted on Saturday, January 27, 2007 - 08:12 am: |
I am currently setting up my home hifi system and have decided against spending the $900 on a cd player that I initially intended on buying, and instead putting that money towards a sound card. The Lynx two B has got piles of positive reviews so I am leaning towards buying that, however I would just like to know whether there is a similar card (or setup) that can provide me with the same audio quality without all the fancy pro features, since I am unlikely to be using them. Any light on the matter would be greatly appreciated. |
Silver Member Username: Arande2
400dB could probably d...,
SouthWest Mi...
Too Many DBs...
Post Number: 975 Registered: Dec-06
| Posted on Saturday, January 27, 2007 - 08:19 am: |
Before I even opened the thread I was going to recommend the Lynx two B  |
Post Number: 2 Registered: Jan-07
| Posted on Tuesday, February 06, 2007 - 06:25 pm: |
Thanks ... looks like a lynx two b it'll B... any second hand /x demo ones available ? HA wishfull thinking... worth a try though  |
Bronze Member Username: Andreas
Post Number: 22 Registered: Sep-05
| Posted on Thursday, February 15, 2007 - 11:05 am: |
It depends on your setup... If you have nice receiver there is no such thing as audiophile card, unless you just mean "any expansive stuff" Or am I wrong? If sound card output is to go straight into the analog input on the amp there are good cards from Auzentech, M-Audio or E-Mu too. |
New member Username: Wavfile
Boston,
MA
Post Number: 3 Registered: Apr-07
| Posted on Thursday, April 05, 2007 - 08:45 am: |
Of course there is the: http://www.presonus.com/firepod.html which is definitely up there in quality. It also has enough ins & outs to really handle pretty much anything you throw at it. M-audio and E-mu have great ones too as well as Roland. Its really kind of just a matter of prefernce from there... There are many to choose from, please take a look at alot of them WavFile |
