Thread: How to split display across two monitors |
New member Username: Crockett50
Post Number: 1 Registered: Jan-07
| Posted on Friday, January 26, 2007 - 06:21 am: |
I have an ATI Radeon 200 Express graphics card, and a monitor cable splitter. The PC has one VGA output socket. The two displays show the same image, but I want to be able to show different images, e.g. Word on one display, and Excel on the other; or drag Excel across both displays. The monitor setup identifies both monitors as Identity 1. Do I need further hardware ? Thanks for your advice, David} |
New member Username: Waxbar1
Post Number: 2 Registered: Mar-07
| Posted on Monday, March 05, 2007 - 05:55 pm: |
Easy. Make the new one a slave of the first one. Then under control panel--> administrative tools--> computer managemnt. you can config your moniters |
New member Username: Zxt
Post Number: 6 Registered: Dec-07
| Posted on Saturday, December 08, 2007 - 02:42 am: |
This might be an old thread but I can't find under Computer Management on how to make monitor a "slave" . |
