Home > Message Board > Computers > Monitors > Multi-Monitor stand
Author Thread: Multi-Monitor stand
Username: Bigjay
Post Number: 81
Ok, need some help. I am in the process of building a new computer for myself. I pretty much have it all figured out except for one problem. I cannot find the multi-Monitor stand that I want. I found the one that I like but the company sells it with monitors already connected and I just want the stand. This looks like a custom design but I don't need the monitors that they have on it as I have chosen better ones to put in it. The stand holds 6 total monitors, 2 rows, 3 moniors each row. On the bottom row, the center monitor is a 30" LCD while the side ones are 20.1" LCD's but are in portrait setup. The top three are all 20.1 but setup in landscape format. Here is a link to the site. http://www.digitaltigers.com/zenview-arena-ultrahd.shtml
It is a zenview stand and I have e-mailed the company to see about buying just the stand by itself but no response yet. Does anyone know where I can find a stand exactly like this? Every place I found only holds up to 19" or 20" LCDs and really like the format of this but for the price they want for this setup, I can get better monitors and spend alot less.
Any help would be great. Thanks.
BigJay
Username: Jgreyorl
You should try out http://www.multiplexpc.com/multiple-monitor-arrays-s/1.htm they have much better multiple monitor arrays and multiple monitor stands.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Monitors > Multi-Monitor stand [ « Previous ] [ Next » ]
