Thread: Want to upgrade my PC,have a couple questions. |
Bronze Member Username: _jw_
OH
Post Number: 45 Registered: Jul-06
| Posted on Thursday, January 11, 2007 - 06:03 am: |
Right now i have a Gateway 504GR Pc and i want to upgrade my CPU(to this one) my Hard drive(to this one)and my RAM(to this one). Now my question is would I have to change anything else to accommodate my upgrades(i.e motherboard)? Here are the spec to my pc-->specs |
Platinum Member Username: Project6
Post Number: 12384 Registered: Dec-03
| Posted on Thursday, January 11, 2007 - 05:21 pm: |
I just sent some help over here. Hope, this is not some spam  |
Gold Member Username: Alias747
Eclipse Ti,
MN
Post Number: 1877 Registered: Apr-05
| Posted on Thursday, January 11, 2007 - 05:23 pm: |
The ram and hard drive will be fine. I am assuming that you are going to leave the original hard drive in place and just add the 500gb one on? That would be the smartest thing to do, you should have 2 SATA connections. The processor is a different story. The link you provided for your computer doesn't say what socket your current motherboard is, but I am pretty certain that the socket type on your current motherboard will NOT accommodate that processor you want. |
Gold Member Username: Mixneffect
Orangevale,
Ca.
Post Number: 1390 Registered: Apr-05
| Posted on Friday, January 12, 2007 - 12:27 am: |
Isaac W, FTW |
