Thread: I need to reset factory settings W/O CD |
New member Username: Pattymarkie
Post Number: 4 Registered: Dec-06
| Posted on Wednesday, December 27, 2006 - 10:06 pm: |
Have a Emachine T2085 and I am missing the original CD that came with it. I want to reset everything back to factory settings and clean off the hard drive. Any ideas on how to do this short of buying a new CD from emachines? Also, I have tried to pop open the CD drive and it won't budge. Will resetting the factory settings help this?? |
Platinum Member Username: Project6
Post Number: 12096 Registered: Dec-03
| Posted on Wednesday, December 27, 2006 - 10:15 pm: |
What is the OS? |
Post Number: 5 Registered: Dec-06
| Posted on Wednesday, December 27, 2006 - 10:42 pm: |
XP |
Post Number: 12100 Registered: Dec-03
| Posted on Wednesday, December 27, 2006 - 10:56 pm: |
Go to Programs Accessories System Tools System Restore From there you will have different options on restoring your PC |
Post Number: 6 Registered: Dec-06
| Posted on Wednesday, December 27, 2006 - 11:26 pm: |
It will only allow me to go back about two months... |
Gold Member Username: Leew
XXXX!!WWWW,
Yokosuka, ...
YAKUDZA JAP...
Post Number: 1188 Registered: Jan-06
| Posted on Thursday, December 28, 2006 - 10:13 am: |
call to customer service Emachine and order this CD,it's will cost you $15... |
Silver Member Username: Appzalien
Cleveland,
Ohio
US of A
Post Number: 127 Registered: May-06
| Posted on Friday, December 29, 2006 - 08:09 pm: |
http://forum.worldstart.com/showthread.php?t=99501 Check this guys post to see if any of it will help you out. |
