Home > Message Board > Computers > Desktops > Archive through January 21, 2007 > What's a good disk partition creator?...
Author Thread: What's a good disk partition creator?
Username: Bsman
Sarnia, Ontario
Post Number: 78
looking for a disk partitioner so i can partition my HD so i can put music on a different "drive"
Username: Bsman
Sarnia, Ontario
Post Number: 79
oh yes it has to be 98 compatible haha any suggestions? and where to get it?
Username: Leew
XXXX!!WWWW, Yokosuka, ...
YAKUDZA JAP...
Post Number: 1134
buy one more HD!
Username: Bsman
Sarnia, Ontario
Post Number: 80
bahaha im too cheap for that. i just want somethin quick, simple.....and cheap:-)
Username: Leew
YAKUDZA JAP...
Post Number: 1137
http://www.freedownloadscenter.com/Best/partition-hd.html
Username: Nd4spd18
Post Number: 147
That software looks like it should work. Make sure to format all of your partitions as FAT or FAT32 if you want them to be win98 compatible.
If you upgrade to XP it has disk partition managment built in.
Username: Bsman
Sarnia, Ontario
Post Number: 81
one problem, wont download..any help?
Home > Message Board > Computers > Desktops > Archive through January 21, 2007 > What's a good disk partition creator?... [ « Previous ] [ Next » ]
