Thread: Quick need info |
Bronze Member Username: Dj_007
Carlisle,
KY
US
Post Number: 27 Registered: Dec-06
| Posted on Monday, December 11, 2006 - 09:34 pm: |
ok guys im upgrading my PC... and im buying thie MOBO http://www.newegg.com/Product/Produ...N82E16813136168 ok and i recently as in like in the past year bough ta 700watt PSU but the CPU power connector on it is only 6 pin.. this board has an 8 pin on it.. will my PSU work wiht this board?? |
Silver Member Username: Nd4spd18
Post Number: 138 Registered: Jul-06
| Posted on Tuesday, December 12, 2006 - 08:13 pm: |
link doesn't work |
Silver Member Username: Motomattic3
California
United states
Post Number: 354 Registered: Oct-06
| Posted on Tuesday, December 12, 2006 - 08:45 pm: |
ya the link don't work please tell the model number of both the power supply and the board or another link. but as far as I know they won't work togather. |
Silver Member Username: Appzalien
Cleveland,
Ohio
US of A
Post Number: 120 Registered: May-06
| Posted on Wednesday, December 13, 2006 - 10:04 am: |
Look here near the bottom of the page, see the adapter that connects to two regular four pin molex connectors and then creates the 8 pin you need? This can be a pain because it uses up two of your regular power connectors and you should also make sure each is connected to a different 12v line for saftey. http://www.playtool.com/pages/psuconnectors/connectors.html Incidentally for the other guys, just because the link didn't work doesn't mean the part number would not run in a Newegg search. http://www.newegg.com/Product/Product.asp?Item=N82E16813136168 DFI Infinity 975X Socket T (LGA 775) Intel 975X ATX : if you look at the photos you will see the 8 pin EPS. |
