Thread: Hardware error code 10 |
New member Username: Iguy_33
Post Number: 5 Registered: Jun-05
| Posted on Tuesday, November 07, 2006 - 06:18 pm: |
I've just installed a pci card in my computer and xp plug and play reconized it installed it and said it had an error that it could not start. I've tried everything i can think of reinstalling it putting it in a different pci slot can't get it to work. Just wondering what i need to do or how to fix this problem? Thanks Austin |
Gold Member Username: Wolfman1966
WEST MONROE ,
LOUISIANA
Post Number: 1169 Registered: Jan-06
| Posted on Sunday, November 26, 2006 - 09:56 pm: |
they may be able to help you here www.techsupportforum.com they are pretty good about helping with comuter stuff..and can get things working most of the time. |
Silver Member Username: Leew
XXXX!!WWWW,
Yokosuka, ...
SPESNAZ. ...
Post Number: 914 Registered: Jan-06
| Posted on Sunday, November 26, 2006 - 10:37 pm: |
This error may appear if a device has insufficient power to operate correctly.Check that the connector pins have not been bent.And try to update driver! |
Platinum Member Username: Project6
Post Number: 11656 Registered: Dec-03
| Posted on Wednesday, November 29, 2006 - 10:51 pm: |
http://88.208.201.18/answerbase/article.php?id=020 Plagiarizing again???? |
Gold Member Username: Leew
XXXX!!WWWW,
Yokosuka, ...
SPESNAZ. ...
Post Number: 1043 Registered: Jan-06
| Posted on Monday, December 04, 2006 - 08:10 pm: |
no not from them Berny! from here...
Post Number: 11728 Registered: Dec-03
| Posted on Monday, December 04, 2006 - 08:13 pm: |
Well done |
