Home > Message Board > Computers > Desktops > Archive through November 26, 2007 > Windows xp pro activation keygen???
Author Thread: Windows xp pro activation keygen???
Username: Newmen
Montréal, Quebec
Post Number: 13
how can i get activation keygen to activate my windows xp pro 2002???
Username: Johnner
Miami, Florida
Post Number: 916
XPKeyen that I have does not work anymore! Somehow Microsoft-Update can tell that is not Validated.
So I’m just like you NEWmen. If anybody knows of any newer program working now please advice!
Username: Nd4spd18
Post Number: 96
A keygen will not work with XP pro or home because the activation will fail. What you need is a corporate (also called volume license) version of XP pro. I can't tell you where to get one but that's what you need. Use this program to generate a key:
application/octet-streamUpload
XPKey.exe (49.2 k)
Set it to XP corp. and Find Key. Use that key to install XP. The corporate version has no activation. Keep in mind that if you download the WGA update it will say that your windows is not genuine if you do this.
Username: Johnner
Miami, Florida
Post Number: 928
M.S
My problem is that I want to install ActiveSync in my computer but it asked me to have the latest update and it does not lets me install it.
I have Windows XP Corp.
Username: Nd4spd18
Post Number: 98
There are several methods of bypassing the windows genuine advantage check, search google for "bypass WGA". I've never had to do it so I can't really tell you how well any of those tricks will work.
Username: Johnner
Miami, Florida
Post Number: 942
M.S.
Thanks for your INFO but I cannot still do it o well anyways I know now that it can be done Thanks again!
Username: Saw_tech_one
Post Number: 11
CAN SOMEONE HELP AND GIVE ME THE KEYS FOR POWERDVD CYBERLINK MY PC WILL NOT PLAY ANY DVD'S
IF CAN HELP IT WILL BE COOL THANXS
Username: Johnner
Miami, Florida
Post Number: 989
Wrong Thread!
Username: Haloser
all you need is the apllication called wpa_kill.exe and it will solve all your problems that is what i used
Username: Annu1984
New Delhi, Delhi
India
how many times i enter the activation key to activate my windows xp pro 2002???
Home > Message Board > Computers > Desktops > Archive through November 26, 2007 > Windows xp pro activation keygen??? [ « Previous ] [ Next » ]
