I recently purchased an pioneer navigation unit this came with 2 dvds that have all the map data inthem I'm trying to make a back up copy of the software(CNDV-60M)does anybody know what format i have to burn them in or if aneed a special progam or burner please help
You should have utility on your PC right now that can copy discs. You don't have to copy it into a certain format. A direct copy should work unless it is protected.
