Thread: NO STANDBY OPTION |
Bronze Member Username: V_b_rell
Ontario
Post Number: 22 Registered: May-06
| Posted on Saturday, September 23, 2006 - 02:36 pm: |
Someone please help I dont have a standby option when I click on Shut Down all i get is shut down and re-start with the stand by option in grey Ihave an MDG Media Centre Upgrade .... |
Silver Member Username: Wolfman1966
WEST MONROE ,
LOUISIANA
Post Number: 550 Registered: Jan-06
| Posted on Sunday, September 24, 2006 - 11:11 am: |
try this link, maybe it will help http://support.microsoft.com/kb/q188134/ |
Bronze Member Username: Nd4spd18
Post Number: 41 Registered: Jul-06
| Posted on Sunday, September 24, 2006 - 10:05 pm: |
That article says it only applies to Windows 98/ME, he said he has media center edition. First thing I would do is make sure standby is enabled in your BIOS. |
Ontario
Post Number: 23 Registered: May-06
| Posted on Tuesday, September 26, 2006 - 10:37 pm: |
where are BIOS ??? |
Platinum Member Username: Project6
Post Number: 11135 Registered: Dec-03
| Posted on Tuesday, September 26, 2006 - 10:45 pm: |
I don't think you should be messing with your computer if you do not know what BIOS is. Take it to a professional. If your standby option is no loger operational, back track to a day when it was working. You may have installed a program that has conflict. |
Bronze Member Username: S_dot
United States
Post Number: 65 Registered: Jul-06
| Posted on Thursday, September 28, 2006 - 02:09 pm: |
I've had a similar problem before. i just googled "no standy option" and ii found step by step directions of what i had to do in my registry to restore the stand by option |
Bronze Member Username: Rikarddo
Post Number: 68 Registered: Mar-06
| Posted on Thursday, October 12, 2006 - 04:47 pm: |
hi ihave the same problem i know whats bios and i know how to get there but how do i turn it on i tried lookoing for that optio on the bios screeen when i turn the pc on but i just don't see that option. any help |
Post Number: 72 Registered: Jul-06
| Posted on Saturday, October 14, 2006 - 06:25 pm: |
If you can't find power managment options in your BIOS then try the following: Update BOIS to latest version Update motherboard drivers Update video card driver You can download those files from your PC manufacturer's website. |
