Home > Message Board > Computers > Desktops > Archive through January 21, 2007 > Overclocking
Author Thread: Overclocking
Username: Wolfman1966
WEST MONROE , LOUISIANA
Post Number: 384
Ok, I have a new (well, 3 months old) computer with a 3.2 gig Celeron processor, 512mb ram, 60gig hd. Yeah, I know its already fast, but I was wondering what I could do to speed it up even more.Any suggestions?
Username: Illuminator
Post Number: 4655
If you've never done it before, I wouldn't suggest it as it can easily take out your CPU and leave your computer dead until you get a new CPU (which could be $50-120+).
Post Number: 386
Well, I was mainly talking about a software download, or maybe some tricks in windows.
Post Number: 4663
www.getfirefox.com
That will prevent you from getting a lot of spyware and popups that are so commonly associated with IE. Thought lately IE's security updates have been much better.
It's all mostly just keeping the computer maintained, you really won't get it faster with software, it all comes down to the hardware. I'd suggest another stick of RAM as your first upgrade. Maybe get a faster RPM hard drive...though it would kind of be in vain to do too much upgrading to that computer because it has a Celeron processor :P
Post Number: 389
What does Celeron have to do with it? its a good computer...512mb RAM do i need more?
Post Number: 390
just downloaded firefox, then did a little tweak I found on the internet...damn its fast...of course cable internet doesn't hurt either
Post Number: 4673
Yeah, sure.
Celerons just aren't regarded very well by the computer community because of their cheap price matched with lower performance. But they're still great processors that will last forever if they're treated right. Another stick of RAM would be a pretty big upgrade, actually. Shouldn't be too expensive, either.
Post Number: 391
Well, things are definately faster with firefox and the tweak I did. DL was a little over 3000kbps dont know UL speed. Now its 4812kbps download speed, and 356kbps upload speed.
yes I know that RAM is fairly inexpensive, but I have 512mb...how much more should I add? another 512? and will I see a difference if I do?
Post Number: 4676
Yep, another 512 will make a difference for sure, especially for having multiple applications open.
Post Number: 392
OK, but I am wondering...how good is my speed now? is almost 5000kbps download fast, and how about my upload speed?
Post Number: 4688
It's fast. :-)
Post Number: 396
isnt 4812kbps the same as 4.812mbps?
Post Number: 4693
Yep.
Username: Appzalien
Cleveland, Ohio
US of A
Post Number: 96
1 megabits (informal notation: kilobyte = 1024 bytes)
bits 1048576
bytes 131072
kilobits 1024
kilobytes 128
megabits 1
megabytes 0.125
gigabits 0.0009765625
gigabytes 0.0001220703125
4812 kilobits (informal notation: kilobyte = 1024 bytes)
bits 4927488
bytes 615936
kilobits 4812
kilobytes 601.5
megabits 4.69921875
megabytes 0.58740234375
gigabits 0.00458908081054688
gigabytes 0.000573635101318359
your downloading at 600 kilobytes per sec or a little over a half a megabyte per sec.
Increasing your ram or power supply or overclocking your cpu will not effect your download speed in the least. Thats controlled by your internet connection not the speed of your cpu or ram.
Post Number: 4699
^Nice, I didn't see that connection. I thought he was trying to make the computer faster, not the internet speed faster.
Home > Message Board > Computers > Desktops > Archive through January 21, 2007 > Overclocking [ « Previous ] [ Next » ]
