Home > Message Board > Computers > Desktops > Archive through January 21, 2007 > Ram question
Author Thread: Ram question
Username: Kabasa
Post Number: 16
my pc has pc3200 ram i have another pc with pc2700 can i use 2700 with 3200 ram in my pc,will it work
Username: Appzalien
Cleveland, Ohio
US of A
Post Number: 88
Yes, since they are both 184pin sticks of ram they will work but be aware that they will both run at the slower speed 333mhz of the pc2700 ram. If your motherboard is DDR capable you would get the best improvement by getting a second stick of identical 400mhz ram and running them in Dual configuration, this would allow for both sticks being accessed at the same time (dual data rate). See your mobo manual for where to place the two sticks to get the DDR function.
Home > Message Board > Computers > Desktops > Archive through January 21, 2007 > Ram question [ « Previous ] [ Next » ]
