Home > Message Board > Computers > Sound Cards > Having issues with dynex 5.1 sound card
Author Thread: Having issues with dynex 5.1 sound card
Username: Camaro823
British Colu...
Post Number: 622
Ok, so i've disabled the onboard audio card, installed the new sound card, installed the drivers, and changed the windows audio setting to 5.1 surround speakers. My problem is that when I attempt to play a song from the net or from a cd, i'm only getting sound from the left,right and sub. Rears and center do not work, but when I use the test speaker function that is on the software that came with the card, all of them produce sound. Does anybody know if there is a setting i'm supposed to change ?
Username: Clinch
Calgayr, Alberta
Did you resolve this issue? I'm having the same problem.
Colin
Username: Camaro823
British Colu...
Post Number: 898
Yes, I did get this fixed, are you using the same sound card ? cause if you are then you have to adjust a setting in the sound card software that you installed with the card. I can't remember exactly what i did I have since sold the computer that I installed it in. There is a setting I believe on the 3rd tab in the program something to do wit "Q Sound" Fiddle around on that page. Sorry I couldn't be of more help
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Sound Cards > Having issues with dynex 5.1 sound card [ « Previous ] [ Next » ]
