Thread: Ahhhhhh |
Gold Member Username: Dustin3
Tigard,
OR
U.S.
Post Number: 3066 Registered: Oct-05
| Posted on Saturday, August 19, 2006 - 11:40 pm: |
that is what i am wanting to do. i have the internet downstairs, and i want to get internet upstairs... My downstairs is Windows XP, and my upstairs is ME i have a linksys WRT54GS router, currently set-up on my downstairs computer, and today, connected a cat5 ethernat cable from the router, to my upstairs ethernet port (i am pretty sure it's a ethernet port, because it fits nicely and clicks, it is a old IBM computer tho, like 1998 or somthing..) i want to connect my upstairs computer to the internet... i dont know how to do this, i went to home networking etc etc on my upstairs comptuer, and it says it cant find any network adapters. what am i supposed to do????? it would be very nice if you could give me some steps i am sure this question gets asked alot, but i want to make sure i get this right because its not working out, and i have been trying to for an hour.. thanks, bass |
Platinum Member Username: Project6
Post Number: 10046 Registered: Dec-03
| Posted on Sunday, August 20, 2006 - 12:26 am: |
Go here bassman http://www.microsoft.com/windowsME/using/homenetworking/articles/firststeps.asp |
Tigard,
OR
U.S.
Post Number: 3067 Registered: Oct-05
| Posted on Sunday, August 20, 2006 - 12:48 am: |
thanks. but didnt help,  |
Gold Member Username: Illuminator
Post Number: 4187 Registered: Apr-05
| Posted on Sunday, August 20, 2006 - 01:41 am: |
Right click 'My Computer' click properties, then go to the Device Manager under the Hardware tab. Make sure there aren't any yellow exclamation points ANYWHERE. Click on the plus sign next to 'network adaptors' and post all of the devices mentioned. Also, are there any LEDs lighting up where you plugged in the ethernet cable on the back? |
Tigard,
OR
U.S.
Post Number: 3069 Registered: Oct-05
| Posted on Sunday, August 20, 2006 - 02:05 am: |
no explanation marks anywhere under 'network adapter' -- realtek RTL8029(AS)PCI ethernet adapter thats all it says, my router should be set up though because its on, and i went through all of the steps on the install CD, and i can access the internet, with it connected on so... and on my upstairs comp, and downstairs, there is LED lights (green) you prolly remeber me talking about if i have a ethernet port on my upstairs comp, and i pluged it in there, and i was thinking if my upstairs comp has a ethernet card.. would that make a diff??? |
Tigard,
OR
U.S.
Post Number: 3070 Registered: Oct-05
| Posted on Sunday, August 20, 2006 - 02:09 am: |
my upstairs computer only has a PCI dial-up card.. would it be because i dont have a ethernet card, even though i think i have a ethernet port? |
Tigard,
OR
U.S.
Post Number: 3071 Registered: Oct-05
| Posted on Sunday, August 20, 2006 - 02:17 am: |
and also, on my upstairs comp, there is an explanation point on "PCI ethernet controller" |
Post Number: 4201 Registered: Apr-05
| Posted on Sunday, August 20, 2006 - 02:43 am: |
On the upstairs comp, is that the one that has the "realtek RTL8029(AS)PCI ethernet adapter " in the device manager? |
Tigard,
OR
U.S.
Post Number: 3080 Registered: Oct-05
| Posted on Sunday, August 20, 2006 - 02:44 am: |
nope. thats the one i am on right now |
Tigard,
OR
U.S.
Post Number: 3081 Registered: Oct-05
| Posted on Sunday, August 20, 2006 - 02:47 am: |
my upstairs shows: under device manager: "dial-up adapter" ------ and thats all then under other devices "PCI ethernet controller" -- with an explanation point next to it |
Post Number: 4204 Registered: Apr-05
| Posted on Sunday, August 20, 2006 - 02:56 am: |
There's the problem! You need to get the driver for your ethernet card on the upstairs computer. Try to do it manually by double-clicking "PCI ethernet controller" then click on the 'driver' tab. First, try updating the driver, if that doesn't work, roll back the driver. And finally, if those don't work, uninstall the driver, restart the computer, and you should get a message prompt asking to search for the correct driver(hopefully it should find it). If none of that works, then you'll probably have to open up the computer case and get the model and brand of the ethernet card, that way we can research it on the internet and get the correct driver installed manually. |
Tigard,
OR
U.S.
Post Number: 3085 Registered: Oct-05
| Posted on Sunday, August 20, 2006 - 03:09 am: |
it says its already uninstalled |
Tigard,
OR
U.S.
Post Number: 3086 Registered: Oct-05
| Posted on Sunday, August 20, 2006 - 03:13 am: |
it says device status The drivers for this device are not installed (code 28.) to reinstall the drivers, click "reinstall driver" i do that.. "windows was unable to locate the software for this device" |
Post Number: 4211 Registered: Apr-05
| Posted on Sunday, August 20, 2006 - 03:31 am: |
That's (ironically) probably because you don't have an internet connection to it, so it can't search the internet for the correct driver. :P Looks like you're going to have to take the case off and get the model and brand of the ethernet card so we can search the internet for the driver, then install it manually. By the way, what time is it where you are? |
Tigard,
OR
U.S.
Post Number: 3097 Registered: Oct-05
| Posted on Sunday, August 20, 2006 - 03:42 am: |
like 12:40 but are you positive that i need a ethernet card? and i have no clue how to take the cover off and do all that |
Tigard,
OR
U.S.
Post Number: 3098 Registered: Oct-05
| Posted on Sunday, August 20, 2006 - 03:44 am: |
cause i dont want to buy one and then still have no connection, and wonder if i really needed that.. |
Post Number: 4212 Registered: Apr-05
| Posted on Sunday, August 20, 2006 - 04:00 am: |
You don't need an ethernet card, I mean, it's already in there, the computer just isn't recognizing it...you basically just need to install the correct driver and it should be working fine. Once you find the correct driver (using the net on the working computer) you can just burn it to a disc or transfer it to the upstairs computer via USB jump drive (if you have one). Next step is to open up the case and get the brand and model off the card... |
Tigard,
OR
U.S.
Post Number: 3104 Registered: Oct-05
| Posted on Sunday, August 20, 2006 - 04:05 am: |
USB jump drive???? wtf would this just be temporary? and how do you know i have one in my computer? because of the PCI ethernet controller? thanks man, just tryin to get this right -- any good websites on romoving the cover, and what this thing looks like that i'm tryin to find? |
Tigard,
OR
U.S.
Post Number: 3105 Registered: Oct-05
| Posted on Sunday, August 20, 2006 - 04:11 am: |
answer those questions ^^^ and a computer tech guy said this... Good, the adapter is there. Somewhere is the model of your IBM. Google "IBM Model Number ethernet adapter driver" Expand the driver on your hard disk if ZIP or someother archive format. Then return to Device Manager, right-click the PCI ethernet adapter, Update Driver, and point at the expanded downloaded files for the adapter. |
Tigard,
OR
U.S.
Post Number: 3106 Registered: Oct-05
| Posted on Sunday, August 20, 2006 - 04:12 am: |
i have no clue how to do any of that  |
Post Number: 4213 Registered: Apr-05
| Posted on Sunday, August 20, 2006 - 04:19 am: |
Yeah, I'm pretty sure what he just said was a bunch of technical jargon. Does your downstairs computer have a CD burner? If it does, then we won't get into a USB jump drive, but a USB jump drive is this: http://cins.colstate.edu/images/jumpdrive.jpg To open the case, the left panel comes off (if the CD rom bay is facing you). Just turn it around, and there should be two or three screws holding it on is all, unscrew them and slide the side off, it's really easy. Then, grab a flashlight and shine it on the card that you have the ethernet cable hooked up to and see if you can find a brand and model anywhere (it could be on the top or bottom). You might even need to remove the card to get a clear view of the brand and model. |
Post Number: 4214 Registered: Apr-05
| Posted on Sunday, August 20, 2006 - 04:24 am: |
Hey, I'm going to get some sleep now, I'll talk to you tomorrow if someone hasn't helped you figure this out by then. |
Post Number: 10058 Registered: Dec-03
| Posted on Sunday, August 20, 2006 - 04:35 am: |
and make sure that there is absolutely no power connected to the PC when the cover is off. |
Tigard,
OR
U.S.
Post Number: 3107 Registered: Oct-05
| Posted on Sunday, August 20, 2006 - 04:37 am: |
thanks platnium member i will make sure though. and my downstairs computer does have a cd burner, i burn cd's all the time |
Post Number: 10059 Registered: Dec-03
| Posted on Sunday, August 20, 2006 - 04:59 am: |
First as Jexx wrote, find out the type of NIC(Network Interface Card) card you have in the PC. Go to the PC downstairs and use a search engine to look for the drivers. Once you find them, download to your PC and then burn it to a disk. A regular floppy disk (if you have an A: Drive) should be enough to handle the drivers. Once you have the drivers you can run it on your PC upstairs when you are prompted to load the drivers. |
Tigard,
OR
U.S.
Post Number: 3113 Registered: Oct-05
| Posted on Sunday, August 20, 2006 - 03:00 pm: |
ok. i was talking to this guy on www.computerforum.com and he said i wont have to open the case of my computer to find it... so i looked on the back of my computer, and in black typing it shows IBM machine type = 2153 model number = E3U i dont know if these are right???? or do i have to open the casing? |
Tigard,
OR
U.S.
Post Number: 3122 Registered: Oct-05
| Posted on Sunday, August 20, 2006 - 08:15 pm: |
a guy gave me this http://www-307.ibm.com/pc/support/site.wss/product.do?doccategoryind=121172&temp late=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&brandind=11&famil yind=50004&machineind=0&modelind=0&partnumberind=0&subcategoryind=0&operatingsys temind=121210&validate=true and says its an IBM APTIVA 2153-E3U i dont know where to search on that page, and what to put in the drop-down lists?? |
Tigard,
OR
U.S.
Post Number: 3129 Registered: Oct-05
| Posted on Sunday, August 20, 2006 - 10:22 pm: |
under the drop-down lists, do i put my computer upstairs or my one that i am using right now!! and i cant find any of the software or whatever... |
Post Number: 4234 Registered: Apr-05
| Posted on Sunday, August 20, 2006 - 10:40 pm: |
Use the computer upstairs for all of this. The downstairs computer is working fine and doesn't need to be touched anymore to get the net working on the upstairs comp. |
Post Number: 4235 Registered: Apr-05
| Posted on Sunday, August 20, 2006 - 10:41 pm: |
Except of course, since the downstairs computer has internet, you'll have to search the net to download the correct driver, burn it to CD, and that's it for the downstairs. |
Tigard,
OR
U.S.
Post Number: 3131 Registered: Oct-05
| Posted on Sunday, August 20, 2006 - 10:53 pm: |
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=ibm&lndocid=MIG R-4MSPPT this is the one he gave me... so i downloaded it to a floppy, brought it to my computer upstairs, and then went to 3 1/2 floppy A, and it didnt show up.. grrr i put it in my downstairs one, and it showed up there.. so do i need to reformat it or somthin? |
Tigard,
OR
U.S.
Post Number: 3132 Registered: Oct-05
| Posted on Sunday, August 20, 2006 - 11:15 pm: |
i wrote it to a cd, and it was sucessfully put on my upstairs comp, i dont think it was the right one to download though... cause i went to properties on mu computer, and it still has the yellow mark....... |
Tigard,
OR
U.S.
Post Number: 3133 Registered: Oct-05
| Posted on Sunday, August 20, 2006 - 11:49 pm: |
answer!! haha looked at my ethernet card, and at the end of it, it says: Oasis 03V-0 then below that,,, (dont know if this means anything) 021 2 what do i do? |
Post Number: 4238 Registered: Apr-05
| Posted on Sunday, August 20, 2006 - 11:53 pm: |
Okay cool, so you have the general idea of what needs to be done. Have you tried restarting the computer since you installed the new driver? Get back to this: quote:device status The drivers for this device are not installed (code 28.) to reinstall the drivers, click "reinstall driver" i do that.. "windows was unable to locate the software for this device"
And when it asks where you want to search for the driver, select the CD drive (with the driver burned on CD in the CD bay), the click next and see if that works. If none of that works, it could very well be the wrong driver...at which point I still think it would be a good idea to pop the case off and check it out. |
Post Number: 4239 Registered: Apr-05
| Posted on Sunday, August 20, 2006 - 11:54 pm: |
Didn't see your last post as I was busy typing up my last one, heh. I googled "Oasis 03V-0" and couldn't find anything, where did it say that? |
Tigard,
OR
U.S.
Post Number: 3134 Registered: Oct-05
| Posted on Monday, August 21, 2006 - 12:07 am: |
ON the card. but i dont think thats it... omg, i dont know why i cant find a driver for it!! |
Tigard,
OR
U.S.
Post Number: 3135 Registered: Oct-05
| Posted on Monday, August 21, 2006 - 12:13 am: |
wait.. i turned it over, and it says: Netgear FA311 REV - C1 |
Post Number: 4241 Registered: Apr-05
| Posted on Monday, August 21, 2006 - 12:23 am: |
Awesome, that's it! http://public.www.planetmirror.com/pub/beos/experimental/r5/drivers/net/ One of the .zip files at the bottom of the page should work, I believe they're all drivers, and according to: http://www.bedrivers.com/hardware/info.php?product=210&category=29&sub=34 One of them should work! |
Tigard,
OR
U.S.
Post Number: 3136 Registered: Oct-05
| Posted on Monday, August 21, 2006 - 12:28 am: |
on that page i am looking for netgear or somthin (because thats the model) and i cant find it... how do you know these are the correct dirvers to install? |
Post Number: 4243 Registered: Apr-05
| Posted on Monday, August 21, 2006 - 12:41 am: |
In the second link, the person claims they should work. It won't damage anything. I say download all of them, burn them all to CD, then try installing each one at a time and seeing if you can get one that works. If they don't, at least you know what driver you need. I searched all around Google and couldn't find any other sources for the driver (those that did have it had broken links or were just too outdated to follow up on to get the driver). Post a new thread in the desktop section asking for a driver for a 'Netgear FA311 REV-C1" and hopefully someone should have better info than I do. Google is usually what I use, but I know there are driver databases out there...I'll keep looking for the driver in the meantime if the above don't work. |
Post Number: 4244 Registered: Apr-05
| Posted on Monday, August 21, 2006 - 12:43 am: |
Or just ask for the driver on techsupportforums or the computerforums (sorry, forgot the exact URLs, but I know you know them haha). Those guys are great like you've said, and they should be able to find the driver now that you know what you're looking for. |
Tigard,
OR
U.S.
Post Number: 3137 Registered: Oct-05
| Posted on Monday, August 21, 2006 - 01:55 am: |
HAHAHAHAHAH. jexx, guess what computer i am using right now!! hahaha. the guy on the tech supportforum gave me a great link to a driver that worked
Post Number: 4255 Registered: Apr-05
| Posted on Monday, August 21, 2006 - 02:00 am: |
Awesome!! I'm way glad you didn't have to go through the tedious and likely vain process of having to try those drivers! |
Tigard,
OR
U.S.
Post Number: 3138 Registered: Oct-05
| Posted on Monday, August 21, 2006 - 02:52 am: |
yea. thanks for all your help jexx, really  |
