Thread: ATI ALL IN WONDER 9000 PRO |
New member Username: Ranny555
Nyc,
Ny
Usa
Post Number: 5 Registered: Jun-05
| Posted on Tuesday, August 15, 2006 - 06:12 pm: |
Hi ihave couple of questions hope anyone can help ? I finally suceed to get the internet working. thanks to your help. re the ATI CARD I am trying to install the catrd into the AGP slot but as soon as i starting the computer the computer doesnt upload . i tried to look for thre drivers in intel web but no sucseses . anyone knows what should i do? second question is maybe it doesnt feet for window XP pro (doesnt say nothing a bout windows X PRO )if it is compatible can i upgrade the windows to windows media center? |
Silver Member Username: Bigsim
Australia
Post Number: 173 Registered: Jan-06
| Posted on Tuesday, August 15, 2006 - 07:21 pm: |
Hi Ronco, Whether the card works or not should be independent of the version of XP; graphics cards should be plug-and-play (if not necessarily with the ideal driver). Are you sure the card is seated properly? If it is, are you sure it's not a problem with the card itself? Or even that AGP slot. Maybe you could check your card in a friend's computer, and then check a friend's card in your computer, and at least that will tell you if it's a problem with the hardware. |
Gold Member Username: Evadelparaiso
Puerto Rico
Post Number: 1705 Registered: May-06
| Posted on Wednesday, August 16, 2006 - 12:39 am: |
Ronco: Check again insert properly the video, try clear cmos. Which mobo do you have? Eva |
Puerto Rico
Post Number: 1706 Registered: May-06
| Posted on Wednesday, August 16, 2006 - 12:41 am: |
Windows XP use the same drivers utillities than Media. You do not need change to Media. |
Bronze Member Username: Appzalien
Cleveland,
Ohio
US of A
Post Number: 73 Registered: May-06
| Posted on Wednesday, August 16, 2006 - 11:05 am: |
Do you have video on your motherboard as well? If so,you have to disable the onboard video for the card to work properly. |
Post Number: 9618 Registered: Dec-03
| Posted on Wednesday, August 16, 2006 - 08:13 pm: |
Another common mistake that users do when they get a new video card...they still use the old monitor output and not the new one provided by the new video card. I can't believe how many times I've seen this. |
Puerto Rico
Post Number: 1742 Registered: May-06
| Posted on Wednesday, August 16, 2006 - 11:07 pm: |
Berny: lol sometimes me too. |
