Home > Message Board > Computers > Desktops > Archive through January 21, 2007 > No internet conection
Author Thread: No internet conection
Username: Ranny555
Nyc, Ny
Usa
Hi
I conected USB adapter wireless and set up the network under my network.
i get excellent signal icon but i cant get internet access i tried the repair conection ,message shows repaired but i still get no internet everything looks O.K ,but i cant figure what is wrong.
Thanks for the help
Username: Illuminator
Post Number: 4045
Have you tried resetting the wireless router?
Make sure the browser you're using is enabled to connect to the internet directly(hopefully it's IE, because that's what I'm going to give you instructions for). Go to the 'connections' in IE and delete any connections in the box, then go to "LAN settings" and uncheck any boxes.
Username: Ranny555
Nyc, Ny
Usa
tried that ,doesnt work .
i am getting the wireless sign as excellent but still can not view websites ...
any other way i should go ?
i will reinstall the USB adapter and try a gain but i allready tried it twice.
I dont have Ethernet exit so i can not try do it direct please help
Post Number: 4055
Wifi is a type of direct connection.
Best way to troubleshoot is this: install firefox-another web browser- (http://www.mozilla.com/firefox/) and see if that lets you browse the web. If it doesn't, then you have a problem with your adaptor, if it does then IE is to blame.
Home > Message Board > Computers > Desktops > Archive through January 21, 2007 > No internet conection [ « Previous ] [ Next » ]
