Thread: Cd burning queries |
Bronze Member Username: Jamshed
Mumbai,
Maharashtra
India
Post Number: 21 Registered: Feb-06
| Posted on Monday, August 14, 2006 - 04:55 am: |
I am currently using normal CD-R discs for burning audio tracks to be played on my hi-fi. I recently learned that there are special disc's availible for doing this, i.e., "Music Cd-R's". Does using these make any significant change in the sound quality when played back? Moreover, I use the Windows media player 10 to burn audio CD's rather than Nero. I usually apply volume leveling in the media player before burning. Is this the same as normalising (RMS) in Nero? I found that using normalising (RMS) in nero made the sound a bit sharp and edgy. Is this normal? What percentage should I set the RMS to; default is at 20? Is it better to us the "maximum" option provided in nero than the RMS one? Is there any other way I can make all the tracks on my CD at the at the same level without sound deterioration? Thanks for the help.... |
Gold Member Username: Samijubal
Post Number: 2972 Registered: Jul-04
| Posted on Tuesday, August 15, 2006 - 03:03 pm: |
I can only answer the CD-R part. Music CD-Rs are for use in standalone CD recorders that aren't compatible with PC data CD-Rs. You don't need them in a PC, there won't be any difference. |
Gold Member Username: Illuminator
Post Number: 4061 Registered: Apr-05
| Posted on Tuesday, August 15, 2006 - 03:49 pm: |
How to get all tracks at the same volume? Don't download music...buy it Music CD-Rs really don't matter as nearly any cd player will recognized CD-Rs. The players that don't recognize data CD-Rs with music burned on them are pieces of junk or really old. |
