Thread: DVDShrink problems |
Bronze Member Username: Hamjones2
Post Number: 21 Registered: Apr-06
| Posted on Thursday, August 03, 2006 - 06:21 am: |
Hi, have an HP Pavilion dv4224tx laptop with 1Gb ram and 80gb 5400rpm HD. I downloaded DVDshrink and dvd decrypter and copied one dvd then deleted the dvd file off my laptop but when I tried to use my laptop for normal internet surfing and stuff the next day it was going really slow, i mean REALLY slow, so i uninstalled DVDshrink but left DVD decrypter and the next day it worked fine. Does anyone know why this is, how can a small program like that, which doesn't even run unless i'm using it to shrink a dvd slow down a laptop as good as mine? Any ideas would be much appretiated because i don't want to have to install and uninstall it every time i want to copy a dvd! |
Relevant Product Info
Bronze Member Username: Dicks_ndickweeds
Bonerland,
Country Music
Post Number: 78 Registered: Jul-06
| Posted on Thursday, August 10, 2006 - 04:46 am: |
Low battery power. I always use dvd2one. |
Post Number: 22 Registered: Apr-06
| Posted on Friday, August 11, 2006 - 04:01 am: |
I'm not running it off the battery. Is dvd2one as good as dvdshrink? |
Silver Member Username: Wojopro
Summerville,
SC
Post Number: 243 Registered: Nov-04
| Posted on Thursday, July 19, 2007 - 03:33 pm: |
I use dvdshrink and dvd decrypter and have no problems. Which version do you have? |
