Thread: Reboot Problems |
New member Username: Racer43
Post Number: 4 Registered: May-06
| Posted on Tuesday, August 01, 2006 - 03:07 pm: |
When I reboot my computer it stalls on the Intel Inside screen ( Blue Screen ) Sometimes for hours, then it finally boots up Any suggestions Thanks |
Post Number: 9165 Registered: Dec-03
| Posted on Tuesday, August 01, 2006 - 06:46 pm: |
BSOD? Make sure you don't have any disk on any of the drive bays. What is your OS? How old is the PC? |
Post Number: 5 Registered: May-06
| Posted on Wednesday, August 02, 2006 - 09:42 am: |
no disks in drives windows xp four years old thx |
Silver Member Username: Bigsim
Australia
Post Number: 146 Registered: Jan-06
| Posted on Wednesday, August 02, 2006 - 07:53 pm: |
If it's the BSOD, then it could be caused by any number of things. Google the error that you get (above the line that says "If this is the first time you have seen this message...") and hopefully you'll be able to find someone in the same situation. |
Bronze Member Username: Appzalien
Cleveland,
Ohio
US of A
Post Number: 68 Registered: May-06
| Posted on Friday, August 04, 2006 - 11:00 am: |
Here's something you can try, it can't hurt. When booting keep hitting the F8 key to get into the Safe Mode section and select "most recent good configuration" or something to that effect. If that doesn't work it may also be caused by something you installed recently causing a conflict with drivers which in turn takes forever to load so try removing anything you installed recently to see if you can uncover the culprit. |
