Thread: HELP WiFi Internet |
New member Username: Kngsze
Post Number: 6 Registered: Mar-06
| Posted on Monday, July 31, 2006 - 09:19 am: |
I am having trouble getting my PC to connect to the internet via wireless rooter. I have a LinkSys rooter, and LinkSys adapter for the PC. The rooter can my DSL line and my WiFi adapter is installed and connecting to the rooter. All is fine untill I try to connect to the web, where I get nothing (page cannot be displayed). I am pretty sure that I have configured the rooter properly (UK DSL standards). Am I missing some small firewall settings ? ? Running XP SP2, Windows standard firewall, Tiscali broadband Many thanks |
Silver Member Username: Boyce
Post Number: 307 Registered: Apr-06
| Posted on Tuesday, August 01, 2006 - 12:49 am: |
what you mean all is fine, can your pc access web page from the router something like 192.168.1.1 if not that is the problem between the router and your pc, if you can connect the router setup page, then the problem will be between router/dsl moden to the isp server, most time I say is your router not set up correct. |
Silver Member Username: Donnie1973
Tennessee
Post Number: 427 Registered: May-06
| Posted on Tuesday, September 26, 2006 - 06:06 pm: |
u may need the ip's from ur ips provider. or have them give u dhcp |
Tennessee
Post Number: 428 Registered: May-06
isp i meant |
Bronze Member Username: Elcheche
Post Number: 22 Registered: Dec-06
| Posted on Monday, January 01, 2007 - 04:19 pm: |
hi am tryin to get signal from my brother house i got the antenna but i need to know you guys thin if i use the regular cable like satelite dish cable with some adapters think works with it iam talk about wifi |
Tennessee
Post Number: 509 Registered: May-06
| Posted on Friday, January 05, 2007 - 01:57 pm: |
it depends on the antenna. i would create a point to point bridge from his router to urs. or use access points |
Silver Member Username: Nikk
Post Number: 926 Registered: Sep-06
| Posted on Monday, January 22, 2007 - 05:38 pm: |
You may also check what kind of security you have configured at the router, if the access is based on MAC address you must get the MAC address from the wireless NIC you have, then go to your router configuration and add that MAC address to the list and that's it... |
