Thread: Bin file |
New member Username: Bird73
Post Number: 1 Registered: Jul-06
| Posted on Sunday, July 16, 2006 - 08:34 pm: |
i downloaded a movie. i dont know how to view it because there is a bin and cue file. what can i do? |
Gold Member Username: Illuminator
Post Number: 3448 Registered: Apr-05
| Posted on Sunday, July 16, 2006 - 09:33 pm: |
Burn it to a disc, the cue file will align the bin file so it will play properly. |
Post Number: 2 Registered: Jul-06
| Posted on Monday, July 17, 2006 - 12:07 am: |
thks jexx for replying do i burn the folder or just the files? |
Bronze Member Username: Appzalien
Cleveland,
Ohio
US of A
Post Number: 51 Registered: May-06
| Posted on Monday, July 17, 2006 - 11:44 pm: |
Right click the cue file and select open with Nero then burn to cd at 8x speed or less or the resulting video will be pixelated. What you end up with is a vcd that will play on your tv's dvd player but not the PC (VLC player would play it on the PC). If you want to watch it on the PC get VcdGear and convert the bin/cue to mpeg with the "fix mpeg errors" box checked. |
Post Number: 3 Registered: Jul-06
| Posted on Tuesday, July 18, 2006 - 12:21 am: |
thank ill try it |
New member Username: Kumarg
Post Number: 1 Registered: Feb-07
| Posted on Saturday, February 10, 2007 - 11:52 pm: |
It is very simple to open. Now a days everybody using Nero Smart start. I have studied the problem of open .bin files and written a blog. http://howtoopenbinfile.blogspot.com/ I hope you find solution for that. |
Platinum Member Username: Project6
Post Number: 12882 Registered: Dec-03
| Posted on Sunday, February 11, 2007 - 02:02 am: |
Nice 7 month wait. But thanks!  |
Silver Member Username: Appzalien
Cleveland,
Ohio
US of A
Post Number: 130 Registered: May-06
| Posted on Wednesday, February 14, 2007 - 08:31 pm: |
Not to mention I hate Nero Start Smart. I Don't use it for much at all, I put a link directly to Nero Burning Rom on my desktop instead (C:/Program Files/Ahead/Nero/Nero.exe just right click "send to desktop" "create shortcut" I even use it to burn VIDEO_TS folders to disk by selecting DVD > DVD-Video on the left in the Wizard then hit New and it sets up an empty VIDEO_TS folder for you to fill. Its great when you do it this way, Nero doesn't try to reencode everything into its own format and tell you you don't have enough room for one disk, I hate that bull crap, Nero assuming I want their crappy format. |
