Thread: Tv to Computer |
New member Username: Ep5
Post Number: 1 Registered: Jul-06
| Posted on Sunday, July 09, 2006 - 01:47 pm: |
Hi people, i'm new and so here goes: I am trying to hook up my camcorder up to my computer using anlog AV cables so I can eaisly make homemade DVD's. I have a really tight budget (under $100) so I need somthing cheap that works!! If you need more info, juest say so. Thanks!! |
Bronze Member Username: Zagros
Post Number: 36 Registered: Apr-06
| Posted on Monday, July 10, 2006 - 10:47 pm: |
I think if you buy a firewire card and an appropriate cable your life will be much easier. They are also cheap maybe under $20 each.
Post Number: 37 Registered: Apr-06
| Posted on Monday, July 10, 2006 - 10:49 pm: |
Post Number: 8541 Registered: Dec-03
| Posted on Tuesday, July 11, 2006 - 12:30 am: |
Those are digital interfaces, if your camcorder does not have a DVI output it won't work. If you are using analog cables, you need a video capture card. |
New member Username: Fuctupfido
| Posted on Tuesday, July 18, 2006 - 06:37 pm: |
i have a ati radeon 9500 series video card i would like to hook up my TV to This So That I may watch videos from my computer or even just chill back on the couch |
Post Number: 8756 Registered: Dec-03
| Posted on Wednesday, July 19, 2006 - 08:38 pm: |
What kind of inputs do you have on your TV? |
Post Number: 2 Registered: Jul-06
| Posted on Thursday, July 20, 2006 - 01:48 pm: |
both coaxial and a/v also if i hook up vcr ive got more a/v |
