Home > Message Board > Computers > Motherboards > How can i update my motherboard
Author Thread: How can i update my motherboard
Username: Esco6
Manchester
Uk
i am tying to install a second HDD on my computer it only access 8GB i need to update my BIOS to access more memory on my second HDD HOW DO I LOCATE MY HARDWARE INFO TO FIND MY MOTHERBOARD MODEL
Username: Appzalien
Cleveland, Ohio
US of A
Post Number: 35
The motherboard model no. is usually located between the pci slots and will be painted on the board. Your question is puzzling though, usually the size of the hard drive will be determined by what operating system you use. Hard drive memory is cache memory and typically would never reach higer tham 16mb and the bios would have little to do with that either. I think your mixing apples and oranges here. Windows 98 supports hard drives up to 32gig, is your problem that the system is only seeing 8gb of a larger drive?
Username: Ajr
West Mids!!.., Dudly
United kingdom
Post Number: 36
jimmy forget ken download cpuz http://www.majorgeeks.com/download425.html
It tell u name ur ram board cpu the lot once u find out go goggle then look up maker of modo and flash ur bois if u can all info on makers site
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Motherboards > How can i update my motherboard [ « Previous ] [ Next » ]
