Thread: Help on how to transfer software file |
Bronze Member Username: Bladam
Post Number: 75 Registered: Apr-06
| Posted on Friday, June 23, 2006 - 05:36 pm: |
I had just done a PC recovery, and my Microsoft office is no longer working, and I cant find my cd with the key code, is it possible to transfer microsoft office from one computer to another, I am to suggestion, thanks in advance |
Gold Member Username: Illuminator
Post Number: 3236 Registered: Apr-05
| Posted on Friday, June 23, 2006 - 09:51 pm: |
Nope. |
Post Number: 78 Registered: Apr-06
| Posted on Saturday, June 24, 2006 - 06:19 pm: |
Jexx do you have any suggestions for me at this point |
Bronze Member Username: Appzalien
Cleveland,
Ohio
US of A
Post Number: 37 Registered: May-06
| Posted on Sunday, June 25, 2006 - 09:58 pm: |
Office has files in so many different places all over the hard drive, the registry, system32, in your documents folder as well as Program files and theres more yet. You might try googling this phrase "repair office after OS recovery" and see what you find. Most likely you will need that disk. Try and keep all your software and serials in one place from now on. |
