Home > Message Board > Computers > Processors > XP Home network not working
Author Thread: XP Home network not working
Username: Andreolv
I created a home network twix a PC and laptop both running XP but they are not reading each other. I run Zonelabs but disabled it - still not fixed. Any help?
Relevant Product Info
Username: Spawn_2_extreme
Ontario
Post Number: 12
which is ur main computer, 2nd are both machines running same OS, 3rd, are both machines hooked up to a router, 4th when u make the networking disc, and when u inserted the disc to the other machine what settings did u click on.
Username: Appzalien
Cleveland, Ohio
US of A
Post Number: 33
How about some more info, the more the better. Is it wireless, how did you connect the two, do you have a hub? You can't just plug an ethernet wire between two machines and expect them to communicate, you at lest need an ethernet hub between them.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Computers > Processors > XP Home network not working [ « Previous ] [ Next » ]
