Thread: Motherboard ASUS A8N-SLI Deluxe |
New member Username: Roberta7
Motherwell Scotland
Post Number: 1 Registered: Jun-06
| Posted on Wednesday, June 07, 2006 - 07:18 am: |
Hi, can anyone possibly help me. I have just changed my router to a wireless one which works fine. I also changed the sound card to a Trust 5.1 surround sound card but now im not getting any sound from the computer. The only sound im getting is the wrong key sound(if you know what i mean) but i cant play music or listen to anything. Could it be the router or the sound card or is there a conflict between the softwares? Any advice would be great, thanks!!!! |
Bronze Member Username: Appzalien
Cleveland,
Ohio
US of A
Post Number: 28 Registered: May-06
| Posted on Tuesday, June 20, 2006 - 04:03 pm: |
When you say you changed the sound card did you have a card previously or were you using onboard sound? If you add a sound card to a motherboard that has sound already it must be disabled before the new card will work and the drivers should be removed as well. The driver removal also goes for one sound card to a new one as well. |
Platinum Member Username: Glasswolf
Wisteria,
Lane
Post Number: 12142 Registered: Dec-03
| Posted on Monday, August 04, 2008 - 02:56 am: |
disable the integrated audio in the BIOS then install the new sound card and drivers. that should fix the problem. |
