Thread: Help with Custom Speacker setup |
New member Username: Thegrip
Post Number: 1 Registered: May-06
| Posted on Tuesday, May 23, 2006 - 11:02 pm: |
hi im new with this and sry if any of these have been answered before. I would like to setup an extra bass on my computer so i would have two subs i currently have a Logitech Z-2300 and have and a stock sound card. i have about a 150$ budget and would really like to add another sub. i dont really want additonal speakers at this time but maybe later. Could someone please help me with what i need and how much and maybe even a sight thank you. |
Bronze Member Username: Gamerdude
Ontario
Post Number: 46 Registered: Apr-06
| Posted on Friday, May 26, 2006 - 04:23 pm: |
What u prolly want is anothor sub woofer and the following cords http://www.thesourcecc.com/estore/Product.aspx?language=en-CA&catalog=Online&cat egory=Headphone+Accessories&product=2740879 plug this into the green output on ur sound card http://www.thesourcecc.com/estore/Product.aspx?language=en-CA&catalog=Online&cat egory=Cable+Adapters&product=4218402 Plug this into the device above and ur other green plug form the logitechs http://www.circuitcity.com/rpsm/oid/92231/originURLEncoded/http%253A%252F%252Fww w.circuitcity.com%252Fccd%252Fcategorylist.do%253Fcmpstr%253D%2526bMore%253D%252 6N%253D20012866%252B20012884%2526No%253D20%2526catOid%253D-12884%2526PAGE_ACTION %253D%2526c%253D1/rpem/ccd/productDetailReview.do#tabs PLug the two red and white wires into the two inputs on the sub woofer trun it on adn now ur rdy to go
Post Number: 2 Registered: May-06
| Posted on Wednesday, May 31, 2006 - 09:58 pm: |
well that sounds good what if i want to buy the same sub from logitech from ebay (just the sub no speakers), should i buy the same wires and sppliter idea that you gave me ..... thanks a bunch |
Post Number: 3 Registered: May-06
| Posted on Wednesday, May 31, 2006 - 10:00 pm: |
well that sounds good what if i want to buy the same speakers from logitech from ebay , should i buy the just the splitter idea that you gave me ..... thanks a bunch |
Ontario
Post Number: 54 Registered: Apr-06
| Posted on Thursday, June 01, 2006 - 03:58 pm: |
Yea like that would be 4.2 but just the ione set should be plenty like my buddy has them adn there plenty loud but yea any ways you would want one of theses http://www.thesourcecc.com/estore/Product.aspx?language=en-CA&catalog=Online&cat egory=Headphone%2BAccessories&product=2740879 http://www.thesourcecc.com/estore/Product.aspx?language=en-CA&catalog=Online&cat egory=Headphone+Accessories&product=1419578 i would go with the monster one but the top would do just fine |
Post Number: 4 Registered: May-06
| Posted on Thursday, June 01, 2006 - 05:44 pm: |
ok i found a splitter in my house and it lowered the volume of the speakers. i was wondering i got a new sound card (creative audigy se) at walmart and was wondering if i got another sound card would i be able two run two at the same time my new bud is bout 260 so i was thinkin of goin for a logitech z-5500 to go with my logitech z-2200 do you think that would sound good with the two different models. thx again |
Ontario
Post Number: 55 Registered: Apr-06
| Posted on Thursday, June 01, 2006 - 05:57 pm: |
u could allways get eth 200watt logitechs adn then set ur sound card to 5.1 or w.e it is and the plug the seconded set into the FRONT port they wont be nearly as good but it cheaper or just use a spliter like that minster one i showed you Kyle |
Post Number: 5 Registered: May-06
| Posted on Thursday, June 01, 2006 - 06:25 pm: |
aright so get anther set of the 2200's and just use a splitter and set it to 5.1 ?? sounds good thx man |
Ontario
Post Number: 56 Registered: Apr-06
| Posted on Saturday, June 03, 2006 - 10:54 am: |
Np have fun |
