Home > Message Board > Computers > Speakers > My speakers do not work!
Author Thread: My speakers do not work!
Username: Aria
Las Vegas, NV
YSA
I am a writer so I/S isn't my forte. I got a new Dell from Dad for my birthday. Along with it came two speakers and a Harman/Kardon treble/woofer box. The main speaker has two lines running from it. One small line has a burnt orange connection which matches the color on the other speaker. I plugged it in. The thicker cable has a connection that fits directly in the box. The box has a power cord and I plugged it into my power strip. Now what? If it doesn't go into the computer, that means no sound! Any help would be great and thanks! I asked my DAd and he's lost. Upload
Username: Boyce
Post Number: 99
I believe it should come with like Multi-channel input cable for plug to PC, do you know what model no for that sub?
Username: Project6
Post Number: 8071
Check the box for the manual... you should see a connection diagram for your particular PC or better yet call Dell Tech Support. They have excellent tech support.
Good luck.
Username: Aria
Las Vegas, NV
YSA
Thanks Berny and Boyce. I think my Dad is Dell! No manual for any of it. I have another PC loaded but I can't see where in the world another thing would go. All things are plugged. For Boyce: it came with he input cable which went to the speaker rather than the PC. Still think I better call Dell. This Box, this treble and woofer/speaker system are by Harman/Kardon. Upload
Username: Illuminator
Post Number: 3018
Explain what you mean by
What is the box? Is this a subwoofer unit? Where does the thicker cable begin and end as far as what it is hooked up to?
Username: Project6
Post Number: 8105
Scarletta,
Have you called Dell yet?
Username: Aria
Las Vegas, NV
YSA
High and thanks so much. Okay it is a subwoofer box. It has the usual power cord and that went into the power strip. The subwoofer box has a connection point in the back. The right speaker has a thick cable, which fit into the subwoofer box. A thinner line connects into the right speaker. There is absolutely no more entry points or extra dangling cords in this equation. I know something has to into the computer itself but what? Thanks!
Username: Aria
Las Vegas, NV
YSA
Oh, does anybody have the Dell number? My last PC was IBM.
Username: Project6
Post Number: 8107
Did those speakers come with a manual?
Username: Project6
Post Number: 8108
http://support.dell.com/
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Speakers > My speakers do not work! [ « Previous ] [ Next » ]
