Home > Message Board > Computers > Speakers > Optical toslink converter?
Author Thread: Optical toslink converter?
Username: Foggy8
Hi
The problem I am having is that the normal phono connection on my laptop is broken, so I am forced to use the optical out to connect to my speaker system. However, my receiver has no optical input connections. Does there exist a cable that converts digital optical signal to stereo analog connections (the red and white RCA)?
Thanks
Will.
Username: Project6
Post Number: 7878
Try here and see if they have what you are looking for.
http://www.partsexpress.com/webpage.cfm?webpage_id=3&SO=2&DID=7&CATID=21&ObjectG roup_ID=597
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Speakers > Optical toslink converter? [ « Previous ] [ Next » ]
