Thread: 1200 dollar budget |
Silver Member Username: Jkidder
Spring hill,
Florida
Usa
Post Number: 124 Registered: Nov-05
| Posted on Wednesday, May 03, 2006 - 05:45 pm: |
my aunt wantds a starter computer and her budget is around 1200... she uses computers but isnt that good and wants a good functional starter computer for around 1200.. please help.. thank you |
Post Number: 7838 Registered: Dec-03
| Posted on Wednesday, May 03, 2006 - 06:13 pm: |
What will be the primary use of this computer? Gaming, documents, internet browsing, e-mail? |
Gold Member Username: Illuminator
Post Number: 2955 Registered: Apr-05
| Posted on Wednesday, May 03, 2006 - 09:05 pm: |
A starter computer for $1200?? That's quite an amount for a 'starter' computer in my mind. For that price a laptop might even be a better choice. |
New member Username: Seanpenn
Post Number: 7 Registered: Jan-06
| Posted on Friday, June 02, 2006 - 05:51 am: |
Building it is better but i assume you don't know how So i'll tell you the specs you want 1. 17 inch flat screen monitor will do her plenty 2. Go with AMD X2 dual core. (dual core is worth it) Or if you like intel then Pentium D (dual core) 3. 1 GB ram 4. At least a 200 GB hard drive 5. Must have a DVD burner Reasons why is because you want to make the most out of your money. THese upgrades don't cost that much and will last you the next 5 years
New member Username: Aculous
Post Number: 9 Registered: Jun-06
| Posted on Monday, June 05, 2006 - 02:52 pm: |
depends on if you want a ready made system or not. I would say pick an HP and save a little of the hassle. Since you're on a budget heres what you should get. HP Desktop with an AMD 64 3500+ 512 MB Ram HP Monitor 17" Flat screen LCD Canon printer Now you can get all these components for less then 1200$ add in microsoft office. Ask for the student and teacher edition which has everything in it except the 300$ price tag and you should be good to go. |
