Home > Message Board > Computers > Networking > Boyce please answer my question!!!!!!!!!
Author Thread: Boyce please answer my question!!!!!!!!!
Username: Rikarddo
Post Number: 17
boyce i send you a private message but u didn't answer please read it and give me an answer.
Username: Boyce
Post Number: 52
I am sorry, I don't know I get PM, beside anyone can tell me how to check it, thanks.
Username: Rikarddo
Post Number: 18
all i wanted to know if this means that i only need a wireless router.
I just pick linksys wireless router for a example,
from cable modem (provided by suscom) RJ45 (Lan port) connect to a linksys (WRT54GS - Wireless-G Broadband Router) WAN port, and than from router LAN port 1,or2 or3 or4, anyone to your house computer LAN Card (network card), you can use the cable come with the router package, make sure your computer obtain an IP address automatic is check.
Then you can set up the wireless network for another computer, I guess you take a look the linksys user guide, which can download at http://www.linksys.com/servlet/Satellite?childpagename=US%2FLayout&packedargs=pa ge%3D2%26cid%3D1115416835852%26c%3DL_Content_C1&pagename=Linksys%2FCommon%2FVisi torWrapper&SubmittedElement=Linksys%2FFormSubmit%2FProductDownloadSearch&sp_prod sku=1115416825841
tanx for helping me.
Username: Boyce
Post Number: 54
Yes, 1 wireless router will work, make sure another computer have wireless network card installed, if not when you buy the wireless router, you can buy the kit, which come with together or ask the guy at the shop.
Username: Rikarddo
Post Number: 19
how do i know if he has a network card
Username: Boyce
Post Number: 56
at window XP : start-> control panel -> system ->Hardward ->network adapters,look for some like WIRELESS network card,
Username: Rikarddo
Post Number: 21
this is what he gots
intel® 82559 Fast Ethernet LAN on motherboard.
is this right or not. if is not do i need it.
Username: Rikarddo
Post Number: 22
my bad does he needs it
Username: Boyce
Post Number: 58
no, that is not wireless, he need buy one, go for a USB one, easy for your guy to install.
Username: Rikarddo
Post Number: 23
how expensive is that?
Username: Rikarddo
Post Number: 24
so he only needs that wireless card and a
WRT54GS - Wireless-G Broadband Router right.
Username: Boyce
Post Number: 60
Yes, not just WRT54GS, any wireless router will work and check it out http://www.bestbuy.com/site/olspage.jsp?type=category&cmp=&id=pcmcat62200050104
Username: Rikarddo
Post Number: 25
yeah but wich one comes with that wireless card.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Networking > Boyce please answer my question!!!!!!!!! [ « Previous ] [ Next » ]
