Home > Message Board > Computers > Speakers > Klipsch ProMedia 2.1 - What wires to ...
Author Thread: Klipsch ProMedia 2.1 - What wires to solder to what pins...
Username: Pennstateemt
Okay, so I ended up tearing the metal piece of the male 6-pin min-DIN connector that goes into the pre-amp connection on the subwoofer of my Klipsch ProMedia 2.1 system. I cut the bad male plug off the wire, and unfortunately cannot get inside the connector to see what color wires are soldered to what pins.
I bought a replacement connector but need to know what cables get soldered to what pins.
Does anyone have a link to a diagram that might help me?
Thanks!
Ben.
Username: Gamerdude
Ontario
Post Number: 27
Call thema nad ask them or just tell them what happen
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Speakers > Klipsch ProMedia 2.1 - What wires to ... [ « Previous ] [ Next » ]
