Home > Message Board > Computers > Speakers > Speakers Echoing
Author Thread: Speakers Echoing
Username: Mikewhite
Amherstburg, Ontario
Post Number: 19
Hmmm, having a little trouble here guys, glad to get any suggestions. I don't know what I did, but my speakers seem to be echoing? Everytime I hear a song or a click-sound it echoes for a short time after. I'm not sure if it has to do with a setting inside the computer itself, or if it's actually a problem with the speakers. I've tried adjusting some things in Control Panel but nothing seems to do the trick. Thanks for any help!!
Username: Illuminator
Post Number: 2917
I would guess it is a problem with the sound output as I have never seen a problem with speakers having an 'echo' noise. A great way to test it would be to hook up some headphones to the sound output and see if they echo. Assuming that they do (meaning it's a PC problem) I would see if there is any extra sound card software that came with your system. Most have some type of reverb or echo setting as a feature.
Username: Mikewhite
Post Number: 26
haha got it, it was in control panel, not the regular sounds icon though, a different ojne that had nothing to do with sound!!
Username: Blahzenk
yeah okay, could you maybe suggest what that little different icon was?
Username: Jennywhenny
I am having trouble with the exact same problem, except I have no clue how to fix it. The speakers aren't new, I've had them for awhile and they usually work just fine. Recently they started to echo when I click or listen to music or anything and I don't know what to do. Help would be ver much appreciated.!
Thanks(:
Jen
Nevermind, apparently someone set it to sound like I was in a *freaking* (watching language lmboo) stone corridor. SO.. i got it now(: thanks anyways xD
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Speakers > Speakers Echoing [ « Previous ] [ Next » ]
