Home > Message Board > Computers > Monitors > My Plasma Screen Turns White....
Author Thread: My Plasma Screen Turns White....
Username: Sirjakeup
At times just randomly, all of a sudden my screen just turns white and stays there, sometimes for just a few seconds, sometimes I have to restart, any idea what’s wrong?
Relevant Product Info
Username: Project6
Post Number: 6802
How old is the set?
If it is still under warranty you should have it serviced. That is not normal at all.
Username: Sirjakeup
It's a monitor for my computer, only about 3 years old.
Username: Project6
Post Number: 6840
Sounds like a video card problem, if a re-start solves it. Try connecting the monitor to another computer. If the problem persists then it is the monitor and needs to be replaced.
Username: Illuminator
Post Number: 2763
You need to figure out if it is the computer or display. I would assume it is the display and the problem is located in the video pcb. Plasma's aren't made very well in my opinion-if you have to have one, Pioneer and NEC are the way to go.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Computers > Monitors > My Plasma Screen Turns White.... [ « Previous ] [ Next » ]
