Home > Message Board > Computers > Networking > HELP!!! my computer is being dumb!!!
Author Thread: HELP!!! my computer is being dumb!!!
Loogala
I have an t2042 emachines home desktop computer, and recently it just stopped working. Anything internet related wont work. Everything else works. Does anybody know how to fix this?
Username: Project6
Post Number: 5398
How are you connected to the internet?
Who is your ISP provider?
Username: Hunterjames
Post Number: 14
1. Check if any plugs are loose
2. Check the device manage to see if your network card driver is correctly installed or modem driver depending on how you access the internet
3. open up the command prompt (start Menu -> run -> type "cmd" (winXP) --> "type ipconfig" (without the quotes) to see if you have an ip address.
4. If you have an ip address (ex.24.43.34.53) then check your browser settings.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Networking > HELP!!! my computer is being dumb!!! [ « Previous ] [ Next » ]
