Thread: Logitech Z5300e or Z5500 |
| Posted on Saturday, February 04, 2006 - 09:06 pm: |
hey all, for those with the z5300e or z5500, i would like to know how long are the speaker cables. i want to mount the speakers to my wall near the ceiling on all 4 corners of my room. i want to know so that i can plan out everything and prepare to buy extensions. my room is 12'x 12'. the ceiling is the average 8'. |
New member Username: Spawn_2_extreme
Ontario
Post Number: 7 Registered: Jun-06
| Posted on Tuesday, June 20, 2006 - 05:49 pm: |
I've used both setups before, and I can guarantee that you will need to get extensions, if you go with the z5300, the two front are roughly about 5ft and the two rear are about 7 ft, you'll need to go to the source and get some splitters, and some RCA extensions. The z5500 wiring I believe has changed, When I recieved a z5500 at my store the cables were analog, then a few months later the connection hook ups were bare wire which u had to put into the speaker manually, so which ever one u buy, you will need to extend the wiring. |
Bronze Member Username: Seanpenn
Post Number: 13 Registered: Jan-06
| Posted on Monday, July 10, 2006 - 08:14 am: |
Stick with teh Z5500 ... they are simply the best 5.1 speakers |
Post Number: 8534 Registered: Dec-03
| Posted on Monday, July 10, 2006 - 09:09 pm: |
How are they the best? |
Bronze Member Username: Gamerdude
Ontario
Post Number: 78 Registered: Apr-06
| Posted on Tuesday, July 11, 2006 - 01:46 pm: |
Dam Berny I never looked at ur post count before you really have a lot and go with the promedia form klip 2-wat sattelights adn duel 8 inch sub with less distortion then logitech |
Post Number: 8560 Registered: Dec-03
| Posted on Tuesday, July 11, 2006 - 05:13 pm: |
Does the post count matter? I've also been a member of this forum since 2003. |
Ontario
Post Number: 80 Registered: Apr-06
| Posted on Thursday, July 13, 2006 - 10:28 pm: |
no i just saw it adn was like WOW thats kool tho |
Bronze Member Username: Appzalien
Cleveland,
Ohio
US of A
Post Number: 67 Registered: May-06
| Posted on Thursday, August 03, 2006 - 12:03 pm: |
Did you guys know you can extend the wired remote with an ordinary serial cable with male and female ends? |
