Home > Message Board > Computers > Keyboards > 1 keyboard 2 comps
Author Thread: 1 keyboard 2 comps
Necrologist
Is it possible to splice a ps2 keyboard to control 2 pcs at same time?
I know what a KVM switch does, and that is not what I want. I need to hit the "x" key on 1 keyboard, and send "x" to 2 computers at the exact same time. Thanks in advance
Username: Project6
Post Number: 5239
Yes you can use a KVM switch...you need to alter it so the switches are all on at the same time.
Los Angeles, CA
Post Number: 2458
i didn't know you can do that berny. cool.
Username: Project6
Post Number: 5960
Or he can go wireless and use the codes on both computers.
Username: Hannjeff
Halifax, Nova Scotia
Post Number: 22
Just wondering, why do you want to do this, cause it sounds like a interisting project.
Username: Mrskullz1
Brooklyn, New York
Post Number: 485
dnt know if it is possible...maybe w/ some wireless blutooth
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Keyboards > 1 keyboard 2 comps [ « Previous ] [ Next » ]
