Thread: Computer going crazy |
Bronze Member Username: Jprix82
Post Number: 33 Registered: Jan-06
| Posted on Saturday, January 21, 2006 - 01:48 am: |
I have a Gateway and it will restart then come back on then shut off like someone pulled the plug out then come back on then shut off it will keep doing that untill i unplug what is wrong with it? |
Gold Member Username: Illuminator
Post Number: 2497 Registered: Apr-05
| Posted on Saturday, January 21, 2006 - 04:55 pm: |
Most likely a virus-possibly even a prank. It's easy to edit a shutdown prompt into the registry. Scan it with http://housecall.trendmicro.com and then install and scan it with Ad-Aware. If that doesn't work, you might want to look into hardware issues, first the power supply and then go from there. Also make sure the temparature is at a normal level. |
Post Number: 4888 Registered: Dec-03
| Posted on Sunday, January 22, 2006 - 04:44 am: |
do you know how to start it in safe mode? |
Post Number: 40 Registered: Jan-06
| Posted on Sunday, January 22, 2006 - 11:18 am: |
not really, how do you do it? |
Krazed-Karnie Unregistered guest |
| Posted on Monday, February 13, 2006 - 08:54 am: |
F8 or F11 on bootup keep tapping it |
