Home > Message Board > Computers > Desktops > Upside down screen
Author Thread: Upside down screen
Username: Thugshizz
Long Beach, California
Post Number: 41
I was on the net when all the sudden my computer froze and I had to restart my computer. Once I restarted my computer my whole screen is upside down and I'm force to turn my monitor upsidedown in order to operate my computer. I have no idea what happen and need help asap on fixing this problem. thanks
Username: Project6
Post Number: 4889
What is your OS?
Username: Project6
Post Number: 4890
What monitor are you using and what media graphics are driving your monitor?
helpful
http://www.softwaretipsandtricks.com/forum/hardware-problems/14320-dispaly-probl em-screen-upside-down.html
i used boot last known good configuration
Hello im 13 years old and i know how to solve this problem go to Properties graphic options and then click ROTATOION set it to normal this may be caused by a misfunction in the computer or a inappropriate button pressed but as u see before pressing back to normal it would be on another degree usually 180 HOPE THIS HELPS!!
Hello im 13 years old and i know how to solve this problem go to Properties graphic options and then click ROTATION set it to normal this may be caused by a misfunction in the computer or a inappropriate button pressed but as u see before pressing back to normal it would be on another degree usually 180 HOPE THIS HELPS!!
xx mizz nics xx
hi i have the same problem with my screen but am no good with computers therefore dont no how to get to properties lol plz help x x x
Username: Illuminator
Post Number: 2663
That option normally isn't available with default integrated graphic cards or even some aftermarket cards.
Username: Project6
Post Number: 5751
I don't see the relevance of putting "I'm 13 years old" with that post, do you?
Username: Thugshizz
Post Number: 49
My problem has been fixed but thanks for all the help.. I think I hit Alt,control plus the Up arrrow key and it fixed it. Hope it helps anyone with this problem out.
Username: Thugshizz
Post Number: 50
Alt + Ctrl + up or down or left or Right Key will fix the problem on some computers.. Worked on my comp.
Wayne Rooney
thankyou very much 13 year old!! you solved our problem. we just were tapping the mouse or something and it flipped upside down then we got bad headaches standing on our heads while trying to use the computer. sum1 broke their neck but they're fine now. Cheers.
Los Angeles, CA
Post Number: 2459
i bet the guy who claims to be 13 years old isn't even 13. his probably some old sicko who loves little boys.
Username: Project6
Post Number: 5959
eeewwww
Hey it has happened for me and i tried the ctrl alt up thing and it did'nt work either please help me
Username: Sub__zero
13 years? I think so check the post on the
Posted on Wednesday, February 08, 2006 - 07:54
Spells ROTATION AS ROTATOION
Username: Project6
Post Number: 6755
There are plenty adults that cannot spell.
But if they are that great with computers, they really should know how to use spellcheck.
Username: Demon_pride
Crowder, Oklahoma
Post Number: 63
Guys... it isnt even a guy. Look at the name. BonitaChika = Pretty Girl. She probably is 13, and is just proud to have known how to do it.
Username: Project6
Post Number: 6954
Wonderful.
Username: Nemen
Post Number: 527
excellent lol
Username: Gruven
Posted on Thursday, February 16, 2006 - 05:43 pm:
This works with Windows XP. You can change the Direction of your screen any way you want to.
Ctrl, Alt and up,down,left or right for the direction you prefer.
You can use this when you come across an image on he web that is not upright and want to view it without using a photo program.
You can thank Francisco Recinos.
Thanks Frank. =)
Username: Gruven
***EDITED***
This works with Windows XP equipped with an Intel Extreme Graphics card. You can change the Direction of your screen any way you want to.
Thanks Frank. =)
Username: Ladyfreak
Hi 13 year old...=)
Im a dell tech and i would like to thank you for the instruction. a dell customer is now happy.
Username: Project6
Post Number: 12489
Way to acknowledge there, Dell tech! 6 months late.
Username: Thugshizz
Post Number: 83
Damn and I was just thinking of getting a Dell.
Username: Annamouse
Post Number: 14
he wants to be the little girl
Username: Thunder_lightning
Post Number: 37
Anna sound like you need a man..now go back to sleep..LMAO
Username: Matrix_619
hey excuse me can anybody helpme...
I have the same problem with upside down screen...
i tried : Alt+Ctrl+up... and it didnt work...
I also tried rotating it 180deg. from properties and it didnt work...
does anyone else have another bright idea?
nevamind
gracias bonita chika
Username: Bijan
helo
i face the same problem too
and tried hit the ctrl+alt+arrow button.
but my screen still upside down.
anyone here may help me on this?
Username: Ishumaru
see what you do is... blow your computer up and then just walk away... im not exactly sure how to do it b/c mine cant and im very upset about that but my brilliant mother has done it plenty of times but alt ctrl worked on hers, she has dell inspiron e somthing somthin, you could always just say screw windows and get linux and burn your windows to ashes... or just delete it when you partition but hell linux is free... or you could just build up a desktop because half of you most likely have a shitty computer anyways then get a terabyte hard drive... or you can have my old 1702 meg hard drive from 1997... too bad no one goes antiquing in computers, wow me posting was compleatly pointless i am of no help at all
Username: Serenity_mel
hi the same thing happend to me... and Alt + Ctrl and the arrow (down) key worked for me... thanks for sharing and posting the information
Signed,
Much Appreciated
Username: Aching_neck
My Toshiba laptop it turned out to be Ctrl + Shift + R Key.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Computers > Desktops > Upside down screen [ « Previous ] [ Next » ]
