Thread: Running powerpoint to tv through laptop |
Unregistered guest |
| Posted on Monday, January 16, 2006 - 10:47 pm: |
This is a common question. My laptop doesn't have an s-video output and I want to hook it up to a tv in order to run powerpoint. I was told by a guy at radioshack to buy a device(not sure on the name) that was similar to a tv tuner card that ran through vga. A guy at best buy said I needed their ATI TV WONDER USB wich is primarily for watching and recording tv on your pc. Is this going to work for my needed application? Thanks |
New member Username: Andrewtiger
Post Number: 1 Registered: Jan-08
| Posted on Thursday, January 10, 2008 - 02:14 am: |
if you only want to watch PowerPoint on TV with a DVD player You can burn PowerPoint to DVD with Acoolsoft PPT2DVD A professional PowerPoint to DVD conversion tool which helps you easily burn PowerPoint to DVD, or converts them to MPEG Video. With 3-Click simplicity, you can burn your PowerPoint presentations on DVD with transitions, animations, sound and movies retained. You can even create flexible DVD Menus for your PowerPoint presentations to play on TV with a DVD remote control. |
New member Username: Lisa_2008
Post Number: 1 Registered: Feb-09
| Posted on Friday, February 20, 2009 - 03:04 am: |
Connect the laptop to the TV to view your PowerPoint on TV or using a DVD player to view your PowerPoint on TV. With the second way you need to convert your PowerPoint to DVD format at first. You can use Wondershare PPT2DVD, Camtasia, and so on, just google it |
