Home > Message Board > Computers > Desktops > Archive through June 16, 2006 > Serial ATA Harddrive
Author Thread: Serial ATA Harddrive
Username: Ckutac
I have a serial ATA harddrive installed on my computer, and everytime I try and either reinstall Windows or repair Windows to the computer, it says that it can not find the harddrie. But, when I let it boot all the way up by itself, it will boot just fine off the same hard drive. But I keep getting Windows errors, and I want and need to reformat the drive and start over again. Any ideas on how I can go about this. Thanks.
Username: Mrmikelazott
Independence, Oregon
Post Number: 74
check your bios to make sure it detects it. i need more info about your comp to help you out. is the sata plugged into your mb or to a pci card.
Username: Seanpenn
You might need the SATA Raid drivers on a floppy to detect your hard drive. Goto your hard drive manufactuer website and find it.
Home > Message Board > Computers > Desktops > Archive through June 16, 2006 > Serial ATA Harddrive [ « Previous ] [ Next » ]
